Simulink PlugIns cannot be compiled in previous versions after installing CM 9.0
After the installation of CarMaker 9.0, I want to keep using the previous CarMaker versions and compile new Simulink PlugIns, but an error occurs about Outdated MSYS/MinGW Installation.
The problem happens because CarMaker 9.0 also installs MSYS-2020 and changes the system environment variable. PlugIns created in CM version 8.x and 7.x make use of MSYS-2017.
To solve it, before building the PlugIn in Simulink, execute the following command in Matlab command window:
setenv('MSYS_ROOT','MSYS-2017');
Now it is possible to build the model.
  • Date: 07.07.2020
  • Component: Matlab commands
Matlab/Simulink
PlugIn
