GPU assignment command incorrectly handles spaces for paths
Using the GPU assignment command from SensCompute Image 20.04.3 2024.06.03 can lead to an error for CLI options containing blanks.
SensCompute image version can be verified by executing command from a command terminal: lsb_release -a
Exemplary GPU Sensor start up command: GPU 0 DP-0 -- MovieNX.exe -projectdir "CM_Projects/Test Project/"
which results in the following error message when used with -debuggpu: "Error: Unknown option: Project".
In order to fix this issue, replace the file "/usr/local/bin/set_display.sh" on your SensCompute with the attached file "set_display.sh".
Detailed instructions as per below:
  1. Download the attached file "set_display.sh" to your SensCompute module
  2. Login as root or administrator
  3. Copy the downloaded "set_display.sh" file to the directory "/usr/local/bin" using the command "sudo cp ./set_display.sh /usr/local/bin" replacing the existing "set_display.sh" file
Download: set_display.sh
  • Date: 26.02.2025
  • Component: Sensor Models
