Deactivation of lateral dynamics in MotorcycleMaker
How can I deactivate the lateral dynamics (steering input) of the rider in MotorcycleMaker?
You can set the UAQ DM.Steer.Trq or Driver.Steer.Trq to zero using Direct Variable Access (DVA) or RealTime Expressions. For example type the following command in the Maneuver Commands window:
Eval DM.Steer.Trq = 0
If you set the UAQ Driver.Lat. passive = 1, it has no influence on the simulation in MotorcycleMaker. The reason is, that this UAQ is intended to deactivate the lateral dynamics of the IPGDriver in CarMaker but not in MotorcycleMaker.
  • Date: 21.07.2020
  • Product: MotorcycleMaker
  • Component: IPGDriver
IPGDriver
Motorcycle
Lateral Dynamics
