CarMaker-Vissim co-simulation stuck in Preparation (wait) phase
I am trying to perform a co-simulation between PTV Vissim and CarMaker using the Vissim Interface. However the simulation remains stuck in Preparation (Wait) phase.
What can be checked ?
General recommendation:
1. Check for error messages in
  • CarMaker Session Log (accessible from the menu in CM Main GUI > Simulation)
  • VISSIM IF Log (accessible from the VISSIM IF Add-On GUI). Also, try setting Additional Log to 1.
2 .Check License availability
  • Ensure that the PTV Vissim license is available. For example, if it is a dongle license, ensure that the dongle is plugged in and detected
  • Try starting PTV Vissim independently and ensure that this works fine
3. Check if the VISSIM IF pre-defined examples work
  • TestRun examples are provided as part of the VISSIM IF Add-On installation in CarMaker
  • Try simulating these examples to ensure if they are working
Specific recommendations:
1. Pre-defined examples work fine, but the simulation is stuck when using user-specific road files
  • Ensure an optimal folder structure as recommended in the documentation. Typically, all files are located under one sub-folder
  • Ensure that the steps described in VISSIM IF documentation are completed
    • Are the Vehicle Composition, Vehicle Input (Volume), etc. available in the .inpx file (road network for PTV Vissim tool) ?
    • Is the Driving Simulator set to active in Network Settings of the .inpx file ?
  • Date: 12.02.2021
  • Component: VISSIM IF
co-simulation
Traffic
