Compiling CarMaker exe with CMake for Windows and Linux
How to compile a CarMaker executable for Windows and Linux using CMake?
Prerequisites:
- CMake and Visual Studio Code are installed.
- CMake and CMake Tools extensions are added to Visual Studio Code.
- Download the attached template. It consists of the following files and folders: cmake, src, CMakeLists.txt and Readme.pdf
- Copy the folder “cmake” and the text file “CMakeLists.txt” to the top level of your project folder
- Copy the text file “CMakeLists.txt” located inside src to your project folder also inside src
- Open “CMakeLists.txt” at the top level of the project folder and set CarMaker Version on line 9
- Open the project folder in Visual Studio Code (Check prerequisites)
- Press ctrl+shift+p. A drop down menu will open. Search for “cmake: configure” and select it
The available compilers will show up. Select a compiler - Navigate in the Visual Studio Code Terminal to the folder “build” inside your project folder
- Type-> cmake ..
- Type-> cmake --build . --target install
The compiled executable is located inside “bin” on the top level of the project folder.
- Date: 25.03.2024
- Version: 13.0
- Component: C-Code Interface
