Parts of the CarMaker GUI are cut off when using Ubuntu
Problem: Parts of the CarMaker GUI are cut off when using Ubuntu.
This can for example look like this:
The problem is that the GUIs font is not installed or not installed correctly. This is a known problem of Ubuntu which effects CarMaker. To solve this issue you have to do the following steps in the Ubuntu console (you will probably need admin rights):
1) Update package source
sudo apt-get update
2) Remove faulty package
sudo dpkg -P ttf-mscorefonts-installer
3) Reinstall package
sudo apt install ttf-mscorefonts-installer
To check if the fonts are available under Ubuntu 16.04 use the following command to navigate to the package installation path:
ls /usr/share/fonts/truetype/msttcorefonts/
The files that contain the typical font names (Arial, Arial_Black, Times_New_Roman…) should be available here.
  • Date: 12.12.2019
  • Component: GUI
GUI
Ubuntu
Font
