Importing roads from ADASRP
I want to import roads from ADASRP. What do I need to do and how do i proceed?
Importing roads from ADAS RP is an easy way to automatically generate large road networks based on real life data. In order to do so, you require the following things:
- CarMaker license
- Additional license for the ADAS RP-PlugIn
- An installation of a compatible ADAS RP version (pleases refer to the CarMaker Release Notes for more information on which ADASRP versions are supported)
- A license for ADAS RP which must be obtained from the ADAS RP developer: HERE
If you have the software and necessary licenses, please refer to the CarMaker User's Guide Chapter "Road: CarMaker - Here Map Interface" for step-by-step instructions on how to set up the interface.
- Date: 07.01.2020
- Version: 12.0
- Component: ADASRP
ADASRPRoad
rd5
License
