How can the CarMaker executable be run in debug mode?
When writing c-code extensions you may find yourself in the situation of being able to successfully compile your code but still running into errors while running the simulation. In this case it can be very helpful to start CarMaker in debugging mode.
This article shows an easy to use approach on how to do so using the GDB debugger in CarMaker Office and on the XPack4.
If you want to debug using Visual Studio, please refer to: Link
Otherwise refer to the document attached below:
Download: Debugging.pdf
  • Date: 24.11.2019
  • Version: 8.0
C code
Debugging
gdb
